Paintball Aluminum Plating
Hey, I'm coming from the paintball industry and am looking for a unique way to plate my aluminum marker (gun) and accessories. Several interesting, and eye catching looks have come to mind.
The first was what I was told is "Look around at "physical vapor deposition" or "chemical vapor deposition", which are the technical terms for the process".
The second theme I was looking at is "black nickel" I don't have any pictures of the aforementioned, but I do have the formula for the above process; and I had remembered, a long time ago some one asked me how you do black nickel, and I couldn't find my formula. Well, I found it. Of course be careful with this stuff as always.
The electrolyte consists of:
5 oz. Nickel ammonium sulphate [affil links]
3 oz. nickel sulphate
1 oz. zinc sulphate this on eBay or Amazon [affil links]
2 oz. sodium sulphocyanate
and 1 gallon water.
Use at room temperature and only 3/4 to 1 volt, any stronger and it ends up a gray color. Items should be heavily copper plated, including brass before applying Black Nickel plating.
Anyways, thanks for your time
James Lindsay
- Fairfield, Connecticut
Anodize in almost any color you wish.
Dale Woika
Surface Conversion Sciences - Bellefonte, Pennsylvania, US
