CLEANING ANODIZED SURFACES
IN REGARDS TO: INSPECTING ANODIZED SURFACES
I RELIEVE ALUMINUM BLACK ANODIZED PARTS THAT SOMETIMES EXHIBIT A CLOUDY APPEARANCE.
DOES THIS AFFECT FIT, FORM, OR FUNCTION?
WHAT CHEMICALS ARE SAFE TO USE ON ANODIZED SURFACES TO REMOVE THIS CLOUDY "FILM"?
TERESA METZ
- ROLLING MEADOWS, Illinois USA
Anodizing conditions, if not properly controlled may lead to reverse reaction, I mean, the coating starts to be dissolved by the electrolyte rather than build up.
A high electrolyte temperature maybe causing the problem, or if these cases are isolated, these may be caused by loosening of rack-to-parts contacts during anodizing.
Dado Macapagal
- Toronto, Ont
Further to my reply, if the conditions I stated caused the cloudy appearance, I guess there's not much you can do except to rub and wipe the parts with clean cloth. If the coating specs do not meet your requirements, you'll have to re-anodize them.
Dado Macapagal
- Toronto, Ont
