Thread 133/52
Risk in passivating cres 416
Hello,
I heard of a potential risk in passivating cres 416. Is it true? What is the reason for that? Do you recommend not performing passivation on parts made from cres 416?
Thank you!
Rafael - Nesher, Israel
publicly reply to Ami Givol
There is a real risk if you plan to use the normal nitric based passivations. Use a citric acid based product designed for 416 and it will work well and you should have extremely close to zero risk.
James Watts- Navarre, Florida
publicly reply to James Watts
I'd also recommend that you check out Ted's fine FAQ on the subject of passivation.
Lee Gearhart
publicly reply to Lee Gearhart
