Acid Types in Autophoretic Process
In the Autophoretic process, a "mild acid" is used to etch the surfaces to be coated? Does anyone know what type of acid is commonly used and in what dilution?
Kevin Arcoraci
- Columbus, Indiana
Hey Kevin,
Are you using this material in your process lines?
If so, then write this down:
M S D S
Now, take this to the management and let them know that you know what this means and you need answers. NOW!
tom baker
Tom Baker
wastewater treatment specialist - Warminster, Pennsylvania
WELL SAID TOM
John Tuohy
- Ireland
We do not use an autophoretic process at our facility, however, we supply rubber parts to customers that have to "endure" this process. I just wanted to make sure that our compounds were compatible with the fluids involved with the autophoretic process.
Kevin Arcoraci [returning]
- Columbus, Indiana, USA
Hi, Kevin. It's hard to say exactly what steps proceed the autophoretic process, but probably phosphatizing which uses phosphoric acid -- indeed a fairly mild mineral acid. Rubbers, PVCs and polyolefins are probably resistant.
Sorry for the earlier misdirected responses, but at least this way the readers can see an example of why we ask that folks post their 'real world situation' rather than 'abstract questions' :-)
Hi Kevin
The acid used inside the Autophoretic bath is HF with fluoride activity = 250-300 mA
On the other hand, some autophoretic processes use acid pickling (HCl,H2SO4 ,..)
Khaleed El Deeb
July 10, 2011
