Laser cut parts
What machines are out there to remove oxide from the edges of laser cut parts prior to paint?
Dean Baumansystems control - Iron Mountain, Michigan, USA
Hi Dean,
This oxide can be effectively removed by chemical means. Proprietary products are available for this purpose.
- Naperville, Illinois
Any mechanical machine system will remove oxides as well as some chemical processes; therefore, your question is hard to answer. Maybe you should ask how much labor, time, or cost of equipment do you want to spend and/or what is the desired end result and is the part(s) to be treated or painted.
AF Kenton
