BLACK OXIDE SET-UP
birchwoodYouTubeBlackOxide
I was told to set-up a Black oxide line with no specification or the amount of tanks and rinse tanks needed. The type of material suitable for the chemical. Can any specialist help me out. Must the black oxide be every time comes out black after plating process or is it blue-black.
Tessensohn Albert
It'll come out black unless the substrate is highly polished, in which case it will be blue-black.
But real black oxide operates at about 290 °F, which means when water is added to make good the evaporation losses it can instantly flash to steam and cause the tank to blow boiling hot caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] over everyone if it's not done right. You shouldn't design this yourself; get a professionally designed black oxide tank or use a proprietary room temperature blackening solution. Talk to Heatbath or EPI / Electrochemical Products Inc. [a finishing.com supporting advertiser].
Sorry! Site is temporarily read-only as we deal with
intense Chinese hacking crashing e-mail servers.
