Nickel Electroplating
Q. We are manufacturers of mincer machines. We need complete information about the following things:
1- bright nickel plating
2- rectifier
Mohammad Ramzan
- Faisalabad, Punjab, Pakistan
thumbs down signAnd without any further information, your needs are not going to be answered.
James Totter
James Totter, CEF
- Tallahassee, Florida
A. Hi, Mohammad.
Indeed, each of these subjects fill entire books as James implies. I would especially suggest the Metal Finishing Guidebook or the Electroplating Engineering Handbook this on eBay, AbeBooks, or Amazon [affil links] . After you've had a quick look at one of these, if you have more specific questions, I'm sure James or I, or one of our other readers, will be able to help you address them! Good luck :-)
December 7, 2010
Q. State different types of baths in the process of nickel electroplating?
Ahmed Ismail
Ainshams University - Cairo, EGYPT
A.
Table 3 - Nickel electroplating solutions
Electrolyte Composition1), g/L Watts
Nickel
Nickel
Sulfamate
Semi-Bright
Bath2
  Nickel sulphate, NiSO4.6H2O 225 to 400 300
  Nickel Sulfamate, Ni (SO3NH2)2 300 to 450
  Nickel Chloride, NiCl2.6H2O 30 to 60 0 to 30 35
  Boric Acid, H3BO3 30 to 45 30 to 45 45
Operating Conditions
  Temperature, °C 44 to 66 32 to 60 54
  Agitation Air or
mechanical
Air or
mechanical
Air or
mechanical
  Cathode Current Density, A/dm2 3 to 11 0.5 to 30 3 to 10
  Anodes Nickel Nickel Nickel
  PH
2 to 4.5
3.5 to 5.0
3.5 to 4.5
Mechanical Properties
  Tensile Strength, Mpa 345 to 485 415 to 610 -
  Elongation, % 10 to 30 5 to 30 8 to 20
  Vickers Hardness,
  100 gram load
130 to 200 170 to 230 300 to 400
  Internal Stress, Mpa 125 to 185
(tensile)
0 to 55
(tensile)
35 to 150
(tensile)
RAID B
- Turkey
