The galvanizing process explained?
I am currently writing a play that involves the discussion of the galvanizing process for nails.
How many people are going to want to watch a play about nails, you ask? Well, for a short time in the late 70's I worked as a galvanizer at the Independent Nail Corporation in Bridgewater, MA. I am using the process as a second story line in my play and I am interested in getting information about the actual step by step process of the procedure.
While I remember having to slowly(!) dip the nails into a big cauldron of bubbling zinc and then wash them off after they came out, I am unsure of the process before they arrived at my station. I DO remember that they had a terrible acid-like smell. Any help that you could give me in this search would be greatly appreciated. Thank you for your time.
Sincerely,
Jack
Jack G [surname deleted for privacy by Editor]
- Sacramento, California
"Handbook of Hot Dip Galvanization"
by Maass & Peissker
galv_hot_dip_handbook2011
Hi, Jack. The nails would be cleaned in a caustic cleaner, pickled in hydrochloric acid (which is the acid-like smell you speak of), dipped in a flux sort of like what is used for soldering, and then go to your work station for dipping in the molten zinc. After that, on to rinsing, probably with a dilute chromic acid.
Break a leg, and let us know when it gets to Broadway!
