  Thread 128/71
How to Make & Use Liver of sulfur
Q. I know that caustic is a corrosive type of chemical, but is there any specifics to what type of caustic solution to use for the mixture of liver of sulfur?
Chris Mcghee
- Hamilton, Ohio
publicly reply to Chris Mcghee
Liver of Sulfur
liver_of_sulfur
A. Hi, Chris. Liver of sulfur for jewelry blackening is widely available and very inexpensive. You can buy it as crystals or as a pre-diluted liquid. Except for exceptionally large industrial users, it's probably much cheaper and certainly a lot safer to buy a commercial product. Here are a couple of sources ⇨
I don't know for sure the context where you read "caustic", but the word is not just an adjective, it is also slang for "caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] " (sodium hydroxide). This is a very strong chemical that should probably be reserved for industrial use. Good luck.
publicly reply to Ted Mooney
A. Liver of sulfur is sulfurated potash mostly consists of potassium polysulfides. It is alkaline, and will turn silver and some other metals black on contact.
Neil Bell
Albuquerque, New Mexico
publicly reply to Neil Bell
A. caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] is indeed corrosive to skin, and that is usually what is meant when a chemical is designated corrosive, but so is acid a corrosive. Caustic soda is very alkaline, the hydroxyl ion [OH]- is very reactive, which is what attacks skin, and a strong acid, like sulfuric or hydrochloric is corrosive because the proton [H]+ in the molecule is very reactive.
Your question seems to be related to how to keep the sulfide at a high enough pH so that we don't generate H2S (hydrogen sulfide (gas)), which is what happens if the pH gets too low. You would most likely use sodium hydroxide (caustic soda) or potassium Hydroxide (caustic potash) to adjust the pH of your solution to keep it above 8 or 9, I suppose this would be high enough. What does your formula call for as a pH level?
These sulfides used for antiquing will generate hydrogen sulfide gas if improperly used, this is a deadly gas.
Dumping large amounts into the sewer could potentially put sewer workers at risk, if for some reason, the dump encountered an acid dump by someone else into the same sewer. Unlikely, but possible.
publicly reply to Tom Pullizzi
!! I normally don't get into this discussion BUT in Condensed Chemical Dictionary[this on Amazon affil links], 1971 it states "Liver of a term formally used to characterize compounds containing sulfides etc --------.The word is outmoded and should be avoided." This is said in 1971.
If you wish to use "liver of sulfur" you can purchase at gardening supplies nurseries as "lime sulfur", calcium polysulfide. If you wish to antique then dilute to 1-10 ml/litre. If you wish to strip copper use 50% strength.
But please don't try to "MAKE" it if you don't understand, i.e., actually KNOW about chemistry.
Geoffrey Whitelaw
Geoffrey Whitelaw
- Port Melbourne, Australia
publicly reply to Geoffrey Whitelaw
A. Here...
How to use Liver of sulfur
By: John A. Foutz
Liquid oxidizers (Win-Ox, Silver Black, etc.) are easy to apply but are too easily removed. The chemical also tends to creep out long after the work is finished unless the piece is rinsed very thoroughly.
Liver of sulfur is the most effective oxidizer of sterling silver I know of in both cost and performance. It, unfortunately, is the least easy to apply. It penetrates and thus is the most resistant ...
Copy and paste this link in your navigation bar for the Foutz article:
www.ganoksin.com/orchid/archive/9711/msg00480.htm David Dolata
- Ripon, Wisconsin
publicly reply to David Dolata
A. We use Lime sulfur solution (Calcium polysulfide is the a.i.) as a fungicide, and you guys should realize that although not a restricted pesticide, it does have a very nasty acute effect to eyes and other sensitive areas. Proper mixing attire would be the following: face shield this on eBay or Amazon [affil links] , long sleeves and pants, coveralls, PVC mixing apron this on eBay or Amazon [affil links] , chemical resistant boots and rubber gloves this on eBay or Amazon [affil links] . With a pH of around 10, it is caustic enough to do permanent damage quite easily. This earns it a DANGER label-- skull and crossbones type stuff. Yet it is organic. Good stuff, but respect it, people!
Stevenson
farming - Orient, New York
publicly reply to Stevenson
A. Liver of sulfur is not "lime sulfur", calcium polysulfide, but is a synonym for potassium polysulfide or potash sulfurated. Please do not heat the solution or add it to acid as the material reacts (with acid or steam) to evolve hydrogen sulfide gas, which is toxic, flammable, explosive, and even corrosive when moist.
Leona Lengyel
- Adelaide, South Australia, Australia
publicly reply to Leona Lengyel
Blackening of copper at home
Q. Hi guys.
Is there a way to actually MAKE a solution for blackening of copper at home?
I copper-plated a revolver and now I want to blacken the copper plating to make the revolver look like it was blued.
I used a cold blue solution from the gun store and it makes copper jet black BUT it leaves a very slight, barely noticeable greenish tint. Actually it is so slight that no one except for me could notice it but still... it kind of annoys me.
I need something that can blacken copper by making it really jet black or by giving it a bluish or brownish tint .
What should I use?
Svet Tzarev
- Sofia, Bulgaria
publicly reply to Svet Tzarev
A. Hi, cousin Svet.
Geoff has implied -- and I agree with him (although you certainly don't have to) -- that if you don't know the answer, it means you haven't had sufficient chemical training to safely engage in trying to make compounds and mixtures of this sort :-)
Sort of like if you have to ask where to start the incision for an appendectomy, you probably shouldn't try to perform one :-)
Brass Black Metal Finish on
birchwood_brass
A. Liver of sulfur-(LOS) Sulphated Potash...All names for a quite traditional Copper Patina. For what it is worth, the gentlemen posting the question about applying a patina to a copper plated gun barrel, one must use caution as the plating is often quite thin. LOS is quite aggressive, and has been my experience that it will often blast the plating right off the object. Maybe a selenous acid base patina? Check out Sculpt Nouveau. Birchwood Technologies [a finishing.com supporting advertiser] has a nice black patina .
Working with LOS most every day one must take caution. It can be absorbed through the skin, and the toxic component, Hydrogen sulfide gas ("Rotten Egg Smell") deadens your sense of smell as you are exposed to it, making you unaware of the risk. I have become quite ill from accidental exposure to the gas by allowing LOS to combine with something as simple as some citric acid this on eBay or Amazon [affil links] pickle solution, or even Barkeepers Friend this on eBay or Amazon [affil links] . Anything with a pH of 6 or lower is to avoid!
You'll do fine to wear rubber gloves this on eBay or Amazon [affil links] , glasses at least. Good ventilation! Of course, I am doing large areas; small things like jewelry might not let off more Hydrogen sulfide than a fart. (Yes, that's what that is.)
Charlie
Charles D [last name deleted for privacy by Editor]
- Indianapolis, Indiana
publicly reply to Charles D
January 9, 2012
Hi, Charlie.
Folks, make sure you do your research before you decide on Birchwood-Casey. Its a fantastic product, with undeniably consistent results; however, it is designed largely for an industrial application, where things like the disposal of selenium, copper-bearing liquids, and neutralized acids are considered part of the daily routine. You need safety gear to handle this stuff. That particular patina is an acid based patina that etches into the copper in a given alloy, and attaches the selenium molecule chemically. It is not an oxidizing patina that reacts to surface treatment, which if used carefully, can then be flushed with enough water into the waste system.
Where did I get my info? I was one of the consultants that helped to field test their line of gel based acid patinas while I applied the patina and finish to the metal work at the Bonfire Memorial for the Texas A&M students killed at that tragedy. Let me tell you, OSHA and the EPA both had a huge presence felt.
Brian Bales
- indianapolis, Indiana
publicly reply to Brian Bales
A. Liver of sulfur is very volatile. Once mixed with water the solution will be active for a day at best! Don't dissolve all the yellow lumps and hope to keep solution for next time!
Having owned and operated a bronze art foundry for 20 years my advise is switch to sodium polysulfide. this is sold under the name of zinc purifier. It is supplied as a slurpy deep amber colored liquid. This has the same coloring effect on metals as liver of sulfur but the liquid is nowhere near as volatile, meaning the room will not smell and the solution when mixed will stay active for weeks! Good if you have to mix a bath tub sized tank full at a time.
This for those brave enough is much easier to produce yourself.
"Dissolve 480 grams of Na2S.9H2O in 500 ml of water, add 40 grams of NaOH and 18 grams of sulfur. Stir thoroughly and dilute to 1 liter with water"
I know that someone always says "hey mate its safer to buy, leave it to the pros" right! But for anyone living in the rest of the world, often many things taken for granted in the developed world are just not available and there is no choice. Knowledge means choice!
Dave
dave_mune
Dave Mune
mfgr of decorative concrete - Cebu, Philippines
January 28, 2011
publicly reply to Dave Mune
(Expat living in Cebu) - Philippines
Is liver of sulfur safe for jewelry stones?
Q. Hi everybody!
I could really do with some help to a question I have been trying to find the answer for, for quite a few weeks and as yet haven't had any luck!
I just want to know what stones can be dipped in liver of sulfur? I make lots of wire wrapped jewelry but mostly with semi-precious stones/pearls or handmade glass beads attached...can these be dipped into the solution then go into a tumbler safely?
Some people I've spoken to say I can dip ANY stones, but I've seen people do it before I'm just not sure what stones they were dipping!
I'd really appreciate someone helping me out here! I've been asking around for weeks now and no one seems to give me a straight answer!
Many thanks!
Holly.
Holly [last name deleted for privacy by Editor]
Jewelry designer - Lake Mary, Florida
publicly reply to Holly
A. I don't know the answer, Holly, but I understand that most relatively mild chemicals have little effect on most stones -- although I'm starting to see some warning signs at jewelry counters that they have coated their stones for better color; I hope someone can be more definitive.
But it's usually good to remind people that although pearls are often used in jewelry in pretty much the same fashion as stones, pearls are not stones, and they react to chemicals much differently than stones do. Treat pearls as a separate thing from stones when reading messages about jewelry stones. When you read that something does not affect stones, it does not mean that it doesn't affect pearls!
What is a safer way to patina copper than liver of sulfur?
Q. Hi
Is there something safer I can use to patina a copper plate instead of using liver sulfur?
Annette
Annette hagger
student - England. UK
August 27, 2008
publicly reply to Annette hagger
12871
A. Hi, Annette. If you are using the pre-diluted liquid liver of sulfur with good ventilation, on small pieces, and you avoid acidifying it with vinegar in bulk on eBay or Amazon [affil links] or anything else, it sounds pretty safe. Safer would be seal it in a plastic bag overnight with crushed hard boiled eggs, but I think they might be too slow and variable to really do the job. Let us know if you find otherwise!
August 2008
A. A safe inexpensive way to patina copper is simply to add feline urine and let it sit until desired results are achieved. Dipping different textured paper towels and toilet tissue in the urine and placing on the copper will give different textures and patterns.
Make sure to keep it wet. Don't forget the gloves :)
Misty Hall
- Phoenix Arizona USA
August 27, 2014
publicly reply to Misty Hall
Can liver of sulfur restore antiquing to orange copper
Q. I purchased a home that has copper counter tops. My son accidentally spilled vinegar on top of the counter top and unfortunately there was some salt particles on the counter. Needless to say, there was a chemical reaction and I now have a big orange spot in the midst of my beautiful antique brown copper counter tops. Would Liver of sulfur help to restore the antique brown look to the spot? I welcome any suggestions.
Kari Purser
hobbyist - Opelousas, Louisiana
December 2, 2008
publicly reply to Kari Purser
A. Hi, Kari. For countertops that are a dark antique brown like yours, I think it would help a lot even if not a perfect match. Wearing rubber gloves, sponge on a very dilute mixture and see how it goes.
For bright countertops, Brasso and other brass/copper cleaners should remove the raw orange look with a few applications.
December 7, 2008
