Constant Current Anodising
Considering constant current anodizing... By how much does the applied voltage vary in order to drive this constant current through the item(s) to be anodized?
Rob Hammond
- Staffs, England
Rob,
I'm not sure I totally understand your question. Constant current anodizing is definitely the preferred method. I guess the volts you will need will depend on the type of anodizing you do, and the alloys you typically work with. For hardcoat, you will need a minimum of 50 volts, preferably 75. For just decorative work, 20 volts should suffice. In re-reading your question..let me give you an example. For hardcoat..typically 6061 alloy will start at a voltage of around 26.1 (if you are anodizing around 24-26 ASF), and finish up around 50 volts, perhaps a little higher. Other alloys vary in their starting, and ending voltage. However, if you are anodizing at higher current densities than 24-26 ASF, you can obviously expect your beginning volts to be higher.
Marc Green
Marc Green
anodizer - Boise, Idaho
