Autophoretic® Process Application
Has anyone heard of 700 series Autophoretic® paint used for external applications on its own without subsequent organic overlay. To be more Specific, for an aftermarket automotive application. I am interested mainly in UV performance, corrosion resistance and chip resistance of parts coated in Autophoretic® 700.
Thanks in Advance,
Graham Dodd
- Melbourne, Australia
AUTOPHORETIC® 700 Series coating chemicals are a Henkel product.
I do have some literature on it. It is a word document and I can forward it to you. You can contact me from the listing on this site.
Gurvin Singh
Mohali, Punjab, India
Dear Donald,
Autophoretic® chemical coatings are available in 700 & series. These coatings are applied on a degreased panel and prior to pickling for scale removal. ACC gives an improved corrosion resistance 600 hrs min. with 3 mm scribe one side and chip resistance 5+.Capex and operating cost is approx. 50%, however area of application need to be identified for corrosion protection and exposure.
S.K.Garg
- Vadodara, Gujarat, India
700 Series is not good at UV performance but 900 Series is good at UV performance because same not resin.
Se Do Jang
- Korea
