Polishing 6061 T6 aluminum sheet metal
Q. How do I polish 6061-T6 aluminum sheet metal to a mirror finish? I have tried NUVITE compound on an orbital buffer with marginal results. I would like to buff the aluminum and eliminate the grain and scratches, the NUVITE doesn't seem to cut deep enough. Any suggestions on compound, applicators, equipment and technique?
P.S. The aluminum sheets are bare 6061 T6, no Alclad coating.
Dana Thurston
- Portsmouth, New Hampshire
Mothers Polish
mothers_polish
A. Have you tried Mothers Mag & Aluminum Polish this on eBay or Amazon [affil links] ? I've had fairly good results with this.. of course, you must start off with a relatively scratch free surface to begin with. Another option you may want to consider is electropolishing, or a bright dip, both of which should probably be followed up with a very thin anodized coating.
Marc Green
Marc Green
anodizer - Boise, Idaho
A. We have had the same issue regarding 6061 aluminum and scratches. We also found that orbital buffing equipment was the only way to produce a finish that allowed us to buff the part to a mirror finish. Is the final result you are looking for is a buff (mirror polish) finish?
If so, we have found that red sisal wheels roughing the part before buffing on standard cotton wheels is a better and more cost effective solution. That is with our equipment (an in-line buffing "shack"). Not knowing your equipment capability I cannot offer a further solution.
Let me know.
James P. Elwell
polishing engineer - Story City, Iowa
12581
Q. I have used airway wheels this on eBay or Amazon [affil links] and polishing buffers of 100% cotton and even if I remove all the milling I have small areas of burnishing...how can this be removed? I'm doing a full polish on my new kit airplane and I can't afford a mistake. This burnishing resembles cloudy areas.
Jim in Texas
James Madison
- Wichita Falls,Texas
November 7, 2016
"You'll do just fine on your very first try."^"Practice makes perfect."
Although I'm no polishing expert, I know that book knowledge isn't likely to get you all the way. You should get some scrap material and practice rather than starting on an item where a mistake can't be afforded. Letter 800 is about polishing aluminum, and discusses in good length the things that can go wrong including what causes such haze. Good luck.
November 2016
