Thread 125/29
Is powder coating durable enough for a wood stove
Is powder coating durable enough for a wood stove?
James T. Schwitzgebel- Attica, Indiana
publicly reply to James T. Schwitzgebel
I would be concerned about the powder coat being able to handle high enough temperature. Its melting point may be below the max temp of your furnace. I would ask the powder coating supplier how much heat their powder coat can stand.
Tim Neveau
Rochester Hills, Michigan
publicly reply to Tim Neveau
Yes it is possible to powder coat a wood burning stove. In the UK American companies such as H B Fuller & DuPont Powder Coatings supply such products for the coating of BBQ's, which would I imagine reach similar temperatures with local hot spots. I have seen a BBQ put into a high temperature burn off jig cleaning oven with no effect on the coating.
Alex Jennings- Hawarden, Wales, UK
publicly reply to Alex Jennings
