DROP TEST FOR CHROMATE CONVERSION COATING CHECK
Need information about DROP test of chromate conversion coating to validate the existence of coating on a part. One of the specification says DROP TEST MAY BE CONDUCTED USING ARP 70A and 70B per instruction of Macdermid Bulletin ARP 70.
Quamrul MazumderHoneywell - Tulsa, Oklahoma
Golly gee whiz, the finest source for that information, to insure that it is correct, would be Macdermid. They have a tech service dept. that can provide that info quite rapidly.
James Watts- Navarre, Florida
The "ARP" sounds like an "Aerospace Recommended Practice" available from the Society of Automotive Engineers (SAE). Check their website.
Doug HahnPerformance Review Institute - Mason, Ohio
Didn't anyone else read The World According to Garp?! ARP is EXACTLY what Garp was saying.
Macdermid is the best source for the final word, so I will defer to them...but I think it is a common misconception that ARP 70 checks for chromate...rather the chemical reacts to aluminum instead. So, if the chemical reacts and turns blue, it means that aluminum is present. The thicker the protective coating, the longer it takes to turn blue. ARP 70 has nothing to do with chromate, it is just a handy way to determine if your aluminum is coated. Beware of assuming what the coating is!
Jeff BesethElectronics manufacturer - Olathe, Kansas
I could not find the reference to APR 70, but did find ASTM B449, Standard Specification for Chromates on Aluminum and ISO 10546 (don't have title, but should be similar).
www.astm.org
Appendix IX does detail tests to detect presence of chromate and details tests to filter out other potential metals (verify chromate is in the coating and nothing else). FYI - You'll have to pay to see this standard through ASTM or ask if your employer has a subscription.
- Salem, Oregon
