  Thread 124/85
Protection of punched areas of GALVANNEALED (A60) material
I'm a mechanical designer. At our company we manufacture pre-fabricated weather-proof metal buildings. My question is, after we punch holes in our galvannealed (A60) panels, we deburr the punched area with a small hand sander (180 grit). I am concerned that we are damaging the A60 coating, please comment.
Ronald E. Davidson
- Canton, Ohio
publicly reply to Ronald E. Davidson
Cold Galvanizing Spray
You're not damaging it, Ronald, you're completely removing it from the punched areas. In benign environments that's not a big problem because the ganvanneal can sacrificially protect the exposed steel. But with the environment that a roof sees, and the probable retention of moisture under the fasteners, it's not a good situation. I would protect the exposed steel surfaces with cold galvanizing compound Cold Galvanizing Compound / Zinc Rich Paint, or somehow -- with lacquer, paint, mastic, or something.
publicly reply to Ted Mooney
