Substitution for tin plate
Is there a plate that can replace Tin Plate? I mean this plate is also compatible price, mechanical properties, solderability and corrosion.
Mike S. Lu- Indianapolis, Indiana
For comparable price, mechanical properties, solderability, and corrosion resistance, I would suggest tin plating your parts, although maybe I missed something.
But you did not describe what you do, what kind of parts you are making, or what problem you are having with tin.
Please try your best to post your own actual situation, rather than an abstract question, Mike. Thanks.
High purity aluminum may be an alternative to Tin. Aluminum has similar mechanical properties, has been used as a brazing media and offers superior corrosion resistance. Please tell me more about your application.
Gus Vallejo- Minneapolis, Minnesota
One of the main reasons typical to not using tin is the "whisker growth" associated with the metal. Whisker growth in the electronics industry can be a disaster. If this is the issue, most OEM's are utilizing tin-lead to eliminate this situation.
Tim Martinplating shop - Springfield, Massachusetts
November 2013
Thanks Tim. That's an example of why I'd like to know Mike's situation. Tin-lead may be fine for electronics use, but how about for lining a copper pot? :-)
