Surface tension of aluminum
Q. I would like to ask what is the surface tension of Aluminum?
Stanley Tsai
optoelectronic company - Hsin-Chu County, Taiwan
Hi Stanley. Sorry, I have no idea what the answer is, but I'd certainly expect it to be temperature dependent. What's the temperature?
Thanks Ted:
What is the surface tension of Aluminum (solid phase with air) at room temperature.
Stanley Tsai
- Taiwan
I had no idea that solid metals had the property of 'surface tension'. I guess you'll have to wait for somebody else to answer.
"Properties of aluminum Alloys: Tensile, Creep, and Fatigue Data at High and Low Temperatures"
by J. Gilbert Kaufman
aluminum_properties_kaufman
"Physics at Surfaces"
Q. We have a similar question as you showed. My project is to get the surface tension of aluminum/oil system at the room temperature.
According to the Young Equation G(s,v)=G(s,l)+G(l,v)cos(angle), which G express the surface tension. s express the solid,v express the vapor, l express the liquid. the G(l,v),which is the surface tension of oil(liquid and Air) G(s,l) expressed the surface tension of aluminum(solid) and oil(liquid). The G(s,v), which express the surface tension of aluminum(solid) and air. From the equation, the G(l,v) can be obtained from the pendant drop method, Angle can be obtained from sessile method. In order to obtained the G(s,l),the G(s,v) have to first to be known.
So the question I have is what is the G(s,v) at room temperature. If I get it, I can further calculate the surface tension of aluminum/oil.
Stanley Tsai
Taiwan - Hsin-Chu county
So the surface tension of the oil is what you are concerned with? And the characteristics of the solid surface in contact with the oil are relatively unimportant?
Bill Reynolds
Bill Reynolds [deceased]
A. Hey, Stanley Tsai:
The surface energy of crystal aluminum at 300k is 1100 mJ/m^2 under vacuum. Normally, the metal oxide reduces the interfacial energy between aluminum and water. Actually, for the anodized aluminum (alumina),the value of interfacial energy is only 50 mJ/m^2. weidong
Weidong Guo
Dept. of Chem Engineering at the University of Alabama - Tuscaloosa, Alabama
Q. But what is the surface energy for liquid aluminum with its vapor?
Wei Zheng
- Lubbock, Texas
Q. Why can't we obtain Aluminum-Carbon alloy like Steel?
Nguyen Xuyen
metal/carbon composite - South Korea
