Rusting Stainless Steel
Hello everyone,
I am a faux finisher and I need to duplicate someone else's finish. I cannot figure out how they did it. I need to create a rust like finish, VERY quickly, on a stainless steel countertop. The s/steel has been sanded with 150 grit to prep. Most importantly this process has to be achieved within a few hours. I have spent the past week trying every recipe I could find on the web; vinegar in bulk on eBay or Amazon [affil links] , salt, peroxide, muriatic acid this on eBay or Amazon [affil links] and combinations thereof. No success.
While engrossed in experimenting, I failed to do my dishes and left a tin bread pan in my sink overnight. When I got up the next morning.... lo and behold... there was the effect I was trying to create! The bread pan had left rust marks in the sink. No stinky, dangerous chemicals.. just water and the bread pan. So, my questions are... how did it happen? how to I duplicate the process? can I speed the process up?
Thank you in advance for your help.
Michelle Jones
Hello Michelle!
I'd suggest you continue your experimentation, only instead of your bread pan use 00 steel wool this on eBay or Amazon [affil links] : you can cut and shape the wool to the pattern you want. It shouldn't need to be thick; just enough to touch the stainless steel, and possibly thick enough to hold some water. Overnight should be enough time. Good luck!
lee gearhart
Lee Gearhart
I'd hazard a guess that ferrous sulfate this on eBay or Amazon [affil links] would generate the stain you are looking for. It sounds like you're looking for iron staining, and that should do it quickly. At least when I've used ferrous sulfate this on eBay or Amazon [affil links] for wastewater treatment it seemed to stain everything it touched :-)
