Seeking Nickel Electroforming of Wax Models
Hi,
I need to electroform nickel onto three (3) wax models. The models are approximately a 3"x3"x1" solid, with some detail on one front surface. The other 5 surfaces are all flat. I need a large build up of a thickness approximately .050 to .080" of material on all surfaces. Whatever thickness in that range, it needs to remain constant on all surfaces.
Greg Mann - Troy, New York
Ed. note: In your area we would suggest you contact NiCoForm [a finishing.com supporting advertiser].
adv.   nicoform
