Restoring Steering wheels on old cars
I am retired and am a car nut, I am trying to find out the best way to repair cracks and paint a steering wheel of a 48 year old car. Am I in the correct place?
Walter Terry
- Basking Ridge, New Jersey
I don't know if you are going to get many responses to your inquiry, but I'll offer my solution.
I too am into old cars, and had the same problem. I used PVC cement to fill the cracks, and "painted" a coat of PVC cement over the entire wheel.
Bill C.
Bill Coffie
Warren, Michigan
I have restored a few old steering wheels by using epoxy putty to fill the cracks and chips then repainting back to the original color.
Good luck,
Dan Logan
- Portland, Oregon, USA
Clean the wheel several times with as good a cleaner as you can come up with. Simple Green ⇦ on eBay or Amazon [affil link] , Spic and Span ⇦ on eBay or Amazon [affil link] , etc. Wipe the wheel down with Enamel or lacquer thinner ⇦ on eBay or Amazon [affil link] Flammable! until no more residue appears on the cloth. Patch cracks,chips, dings with an Epoxy based material (liquid or paste). File, sand and work the material to original contour. Paint with a bonding primer (assuming the wheel is plastic)then topcoat with whatever you prefer for color match. Woodgraining is a different subject and I can help with that if required. Hope this helps.
Bill Miller
- Shinnston, W.V.
