Electropolishing electrolyte composition
Sir,
We want to know the composition of electro polishing electrolyte. Sir, we have some idea using
orthophosphoric acid 75%
sulfuric acid 25%
and glycerin and some oxides
Sir can you help use by saying the actual composition of the electrolyte and the percentage used for electro polishing steel and iron.
Aboo Backer
electroplating shop - Bangalore, Karnataka, India
There is nothing wrong with the solution you presently are going to try.
tom & pooky   toms signature
It seems to me that the proposed mixture is quite sensible. You mention some oxides. What are those oxides?
Hans Henrik Larsen
- Odense, Denmark
