How to formulate PVC Compounds
Q. How to make PVC Cable Compound for AVSS automotive cable.
Rakesh Jain
- Delhi, India
"Handbook of polyvinyl Chloride Formulating"
A. Rakesh,
Any manufacturer (but not necessarily a supplier) of PVC resins should surely be able to help you and tell what 'additives' are needed for your cable compound ... so that all you'd have to do was to mix the PVC resin (Banbury type mixer?) with those ingredients to come up with a suitable and flexible compound.
Further, any competent extruder of PVC (profiles, pipe etc) would or should also know the answer.
Hope this helps!
freeman newton portrait
Freeman Newton [deceased]
A. Rakesh,
Start from the following formulation:
PVC S-70 or higher 100 phr
DIDP 40 "
Powder NBR 20 "
Stabilizer 6 "
Calcined Kaolin 10 "
stearic acid this on eBay or Amazon [affil links] 1 "
I wait to hear you how this formulation works.
NASER SHAHABADI
- TEHRAN, IRAN
Q. Dear Sirs
How to make PVC compound for waterstop having a tensile strength of more than 13 MPa?
Alexander Barakeh
- Beirut, Lebanon
December 16, 2011
"Handbook of Vinyl Formulating"
Q. I am with a PVC shrink film making company.
Please send how to make PVC shrink film compound or resin. Please send me the formula; I have no idea of this. I'd like to study this -- help me.
sisira
Sisira J [last name deleted for privacy by Editor]
- Sri Lanka
August 17, 2013
junaid
Junaid N [last name deleted for privacy by Editor]
packaging - Karachi, Pakistan
April 11, 2016
April 2016
wikipedia
Shrink Wrap
Hi Sisira., Most people won't really believe that you'd go into a business where you "have no idea" how to make the product you want to sell, and expect to learn how to make it from an internet posting. Whole books must be read to gain even a general idea of how to make such products.
We sympathize that you might be having a language difficulty in trying to get your idea across, but please try your best to describe in detail what you are presently doing, and in what ways it isn't meeting your needs; Thanks!
Hi Junai. Unfortunately, Sisira's posting received no responses in 3 years, and I don't think posting it again with just the name changed will gain a better result. Sorry, but best of luck.
PVC thin profile formulation
Q. Dear experts,
I'm going to enter PVC profile extrusion field as a new entrepreneur. I'm concerned about the formulation of PVC wall panels. I want to use up to 70% calcium carbonate, does it make sense? Can I use as much high level of filler in the formulation of thin wall PVC profiles?
Any answer would be appreciated.
Ameer Hamza
- Lahore Pakistan
February 22, 2017
Women's Wellies
wellie_womans
Q. What formula should I use to make PVC gumboot elongation more than 300% and long lasting durable product
Prateek sahu
- Bilapur,Chhattisgarh, India
July 27, 2017
Q. I am looking for PVC hose formula
omid rastegar
- iran shiraz
October 30, 2017
Q. Hi. I am from Burma and making UPVC windows with imported UPVC profiles from China. I have bought a CRUSHER AND SINGLE SCREW EXTRUDER. I make ELECTRIC CONDUIT PIPES 20 mm and 25 mm
First I crush the cut away pieces of window frames and profiles then I use extruder to convert it into electric conduit pipes. Unfortunately I cannot make the pipes' connections with same upvc crushed pieces, pipe connections require lower K Value. Can I mix with plasticiser to soften this UPVC powder of cut away pieces? Main thing is I want to utilize the cut away upvc profiles, making them into softer UPVC. Kindly suggest.
Than Win
upvc windows - Rangoon, Burma(Myanmar)
November 14, 2017
Q. Hi
I want to start swr UPVC pipe fitting. So I am confused about UPVC compounding. If you have any idea of UPVC fitting material mixing recipe please tell us.
Jemish patel
manufacturers - surat gujarat India
December 11, 2017
Q. What is PVC formulation for glove dotting process?
Sheraz aslam
gloves - Faisalabad Pakistan
July 20, 2018
Requesting mixing recipe of flexible PVC conduit
Q. Hi dear!
I want to start to produce flexible PVC electrical conduit, but I haven't any idea about the mixing proportions of each additive and which additives are a must for its production -- so I need help .
Zinaye Kefale
- Ethiopia
November 6, 2018
Ed. note:
READERS! Apologies but this is not a consulting service; it's a forum where readers help each other, getting back in proportion to what they give :-)
With 10 unanswered questions in a row, it's silliness to continue posting more.
If you answer or have previously offered an answer to any of the 60,000 threads on this site -- we will happily post your question. But we can't continue on this unproductive path and must otherwise discard your question. Sorry :-(
