Solder nickel plated Kovar
I have a electrolytic nickel-plated Kovar part and it has a through hole also nickel plated which I want to solder it to assure that it will not leak. Can I solder it successfully since Nickel is not the best candidate for soldering. Should I use some corrosive flux to break the oxide? Please advise.
Thanks a lot.
Rong Hou
- Richardson, Texas
Use an activated flux containing zinc chloride. Heat indirectly and gently so as not to burn it.
Russell Richter
- Danbury, Connecticut, USA
