Coating stainless steel
We are attempting to use a cyanoacrylate adhesive to bond a stainless steel part to a rubber part. The glue will not adhere to the stainless steel. I would like to know if anyone has a suggestion regarding coating the stainless steel with an aluminum rich coating
(ARC) in order to accomplish this.
Cooper Tire & Rubber - Bowling Green, Ohio
Try using a glue called Sicomet. I used it successfully to bond stainless steel to rubber.
Sergio Lievano- Santa Ana, California
Our company is trying to do the same thing, bond rubber to a 17-7 stainless steel and we're having mixed results. We're using a chemlok
205 primer with a 250 adhesive. We're cleaning with
MEK / methyl ethyl ketone.
If you find anything else that works well, please pass it along.
Thanks and good luck.
- Ann Arbor, Michigan, USA
