Finishing for cast aluminum part
Hi,
I am designing a 3"X4"X1" die-cast part by using aluminum AA 384. The original design of that part is by machining (6061), so I have to anodize it to improve wear and corrosion-resistance. Should I use the same process on the die-cast part?
David Lin- Laurel, Maryland
If it was sulfuric anodize you were using, you can anodize 380 casting alloy, although the voltage required is higher. If it was chromic anodize, alloying elements will be a problem.
