-----Calculations of compressive springs
To whom it may concern,
I am helping a company to replace worn out compressive springs from a mechanical vibratory tumbler also known as finishing mill. Right now I have replaced the old springs to new ones but I need to test its stiffness and compressive strength of these new springs if they match with the old ones.
I have asked a couple of companies specialize in testing the springs but I have been told that I need to work out some calculations first. I need to calculate if the springs are equally subjected to the load which is 2100 pounds.
I would like to know where can I get the necessary formulas. I would appreciate if you could be able to help me.
Yours faithfully,
Zac Lim Daoying- Singapore
I don't know that you will have to do a big calculation. Look at the machine. Are the springs evenly spaced around the perimeter of the bowl? Did you try to contact the bowl manufacturer to get the spring specs? I might also look at using a level in various positions across the bowl to see if it sits level. If it sits level, then I would assume that the weight is evenly distributed (assuming that all the springs are alike).
Dan Brewerchemical process supplier - Gurnee, Illinois
The easiest way for me to calculate linear springs is to think of them as parts of a circuit. The force can be treated like a current. The displaced distance can be treated like a Voltage, and 1/k (where k is the spring constant) can be treated as resistance. Notice that springs in parallel will have equal deflections, and that springs and series with have equal forces. Note: If you are using belleville springs, the calculations will be much more complex.
Hope I helped,
Jay
Engineering - Pittsburgh, Pennsylvania, US
