Au-Sn Alloy Plating Solution
I hope to find out more about Au-Tin Alloy plating.
Qn 1:Is a cost of $1.86 per meters sq of plating reasonable?
Qn 2: If we fix a current density of 0.9 ampere-decimeter sq,and we hope to target a plating thickness of 2 micrometers, does it mean that an area of 1 decimeter sq will be plated? (if we have a current of 0.9 ampere-hour)
Vanessa Yeo Fang- Singapore
2 micrometers thick plating over 1 square meter, that is 10,000 sq. cm will require close enough 39.2 grams of gold.
Yashawant V. Devalelectroplating shop. - Pune, Maharashtea, India
