Chemical cleaning of house piping
Does any one know of a method to chemically clean the house copper piping in lieu of re-piping? We have noticed considerable flow restriction to toilet units due to calcium buildup inside the pipes. I was told that vinegar in bulk on eBay or Amazon [affil links] is one of the possible chemicals since it is effective and environmentally safe.
George Beigie
- Irvine, CA
I can attest that vinegar does a fine job of speeding up the flow in coffee makers. By extension I would expect it to do a good job on hot water piping. But whether cold vinegar would have enough activity, that I don't know. Talk your customers into hot water toilets :-)
George,
First off, I'd go to various plumbing outfits and get THEIR recommendations.
Secondly, if you do use a very weak acid like vinegar (or the same but nice and strong called acetic acid this on eBay or Amazon [affil links] ), make sure you turn on all the taps etc until you notice 'it' coming through.
Thirdly, especially if you are using a true acid (HCl, sulfuric) you MUST flush the system down after 5 minutes and simultaneously pour in an alkaline like Sodium Bicarbonate to neutralize the acid. Then give a nice long flush.
If you leave the 'acid' in too long, it could damage the copper piping.
freeman newton portrait
Freeman Newton [deceased]
