Thread 116/50
Wrinkling Paint
After sanding paint finish off metal surface, priming the metal surface, then spraying on initial coat of lacquer all was smooth and fine. This coat was wet-sanded then a second coat applied. The second coat began wrinkling in spots.
What would cause the wrinkling in spots? Now unable to sand smooth and reapply without the same results.
Linda Gotcher- Lander, WY, USA
publicly reply to Linda Gotcher
The problem you are having is that the 1st coat of paint is already dried to a point where it won't accept paint probably for another 2-3 days. What you should do to fix it is sand it back down put your first coat on and don't wait so long before you apply a second coat and remember 2 light coats with 10 min. between coats is better that one heavy thick coat.
Good Luck,
Gary Kinsey- Pontiac, Missouri, USA
publicly reply to Gary Kinsey
