Health concerns regarding polyester resin handling
Hi,
I'm an artist and want to do a large piece with transparent polyester resin. First of all I want to know how safe is it to work with this resin. Does breathing the vapor of the resin have serious health hazards?
Andres Matute Echeverri- Bogota, Colombia
Polyester resin, as well as the hardener are noxious chemicals. If you have to use them, do it in a well ventilated area, wear eye and hand protection and adequate clothing. If possible, use epoxy or acrylic resins instead of polyester.
Alfonso Hernandez- Aurora, CO, U.S.A.
Andres,
What Alfonso said is essentially correct.
From what I've seen of largish FRP manufacturing operations, ventilation is fairly important, sometimes people use rubber gloves ⇦ this on eBay or Amazon [affil links] , sometimes eye protection, most often they don't.
And an art piece would be far easier for you to do using Polyester which, anyhow, costs less than epoxy. Get some acetone ⇦ this on eBay or Amazon [affil links] Warning! highly Flammable! , too, as that will help you to clean up things!
When you say 'large piece' do you really mean it? Why? Because if you get a whole drum of resin you'd need catalyst and maybe promotor .. in which case NEVER mix the two together and store separately.
Freeman Newton [deceased]
