Why is stainless steel non-magnetic?
Q. I am a grade 6 science teacher. I teach that steel is a magnetic metal, and the question comes up, "why isn't stainless steel, such as is found on the sink faucet, attracted to a magnet? I am at a loss to answer. HELP!
Thomas S [last name deleted for privacy by Editor]
- Kingsville, Maryland
"Driving Force:The Natural Magic of Magnets"
by James D. Livingston
"Magnetism and Magnetic Materials"
A. I'm no expert on this myself, Thomas, but magnetism does not actually work on the individual elements of the alloy; it works on materials that allow the alignments of electrons to be pulled into a particular preferred orientation. The short answer is that some stainless steels, because of the way the nickel combines with the iron, produce a crystal structure that has the electrons aligned randomly and precludes the atoms from being free to move into the orientation that we identify as magnetic.
A. Hello Thomas!
Some stainless steels are magnetic: those whose atomic arrangement is in a body centered cubic or body centered tetragonal orientation can be strongly ferromagnetic. The stainless steel in your sink is usually in a face centered cubic orientation, and it isn't ferromagnetic.
That said, I think your question remains, and my best answer is "Heck, I don't know, and I've got a BS in Metallurgy". Guess I slept through that part of my solid state physics classes that covered the question, and explained then why pure nickel (FCC) and cobalt (Hexagonal Close Packed, which is close to FCC) ARE ferromagnetic.
I guess I'm also saying that the answer isn't obvious, by any means, and that it'd be difficult to give a full explanation to sixth grade students. I'd stick with Ted's answer.
lee gearhart
Lee Gearhart
Q. A lot of welders will tell you to check a metal with a magnet to see if its iron/steel. This obviously doesn't seem foolproof?
drew MANN
D-I-Y - UK
May 30, 2008
A. Hi, Drew. I'd say that being non-magnetic warns the welder that the item is not plain steel, so s/he must give it up or at least proceed differently. But being magnetic is not ironclad proof (bad pun) that it is plain steel that will be easily welded.
July 2, 2008
A. All stainless is not the same. Different types and ingredients. Different properties. There are tables to tell you this.
Look up "passivation".
This is a process that "lines up" the nonferrous molecules on the surface so the stainless does not rust and is nonmagnetic.
Old (more than 20 yrs) 304 stainless is usually nonmagnetic as they all did this extra step so the product didn't corrode. Try it on some old flatware sometime, and then on new. New 304 stainless is usually magnetic-most producers have cut the passivation step as a cost saving measure. Old stainless is usually NON magnetic.
C Laza
plumbing - Milwaukee,Wisconsin
August 13, 2008
Q. I would like to know if a magnet can stick to stainless steel jewelry, if it does is that piece of jewelry a FAKE?
Clarence Anderson
- McDonough, Georgia
October 30, 2008
A. Hello, C. Laza, thanks for your reply which is somewhat accurate, but not fully. Passivation does not have to do with magnetism; it is a chemical process that dissolves iron from the surface so as to deter rusting. 304 stainless steel is still (mostly) non-magnetic (but can become attracted to a magnet as a result of cold working). Stainless which is strongly magnetic is a different type of stainless -- not 3xx series but 4xx series. It is cheaper because it contains no nickel, but there are occasions where it's actually better like knife blades (304 cannot hold an edge).
Hi, Clarence. Some stainless steel is magnetic, some is not. In either case, stainless steel is not a precious metal like gold, nor even a semi-precious metal like silver. So I don't know exactly what meaning you have in mind when you ask whether it's "fake".
November 6, 2008
A. I can shed some light on the question about stainless steel, jewelry and the "fake" question as its the exact reason I followed links to get to this site. I just ordered a fairly expensive watch on line that is purported to be stainless steel, but my curiosity led me to the internet when I noticed a magnet would not stick to either the watch or the ss bracelet. From the reading I've done here, I'm content with new information regarding the molecular arrangements possible and the reasons some stainless isn't magnetic. Thank you!
Michael Williams
- Detroit, Michigan, USA
May 18, 2011
Q. Some people around the planet produce stainless steel foil in a form that is thin enough to handle, like aluminum foil. If stainless is a chemical process on the top of magnetic material, like steel. How is it possible to obtain a non magnetic material like foil when steel itself has to be thick enough to attract a magnet. Yet the foil is made in order of 0.05 mm thick.
Gilbert Sambolin Sr.
- Hallandale, Florida
December 1, 2009
A. Hi, Gilbert. Stainless steel is not a "chemical process on the top of magnetic material". Stainless steel is a solid material where chrome and/or nickel and some other materials are mixed in with steel to produce an alloy that has different characteristics, including a resistance to rusting.
December 2009
Hematite vs. Magnetite
wikipedia
Hematite
Magnetite
Q. I was under the understanding that stainless has hematite (non magnetic ore) and magnetic steel is made with magnetite ore. Obviously there are nickel/chrome ext. But I'm just referring to magnetic properties.
henry vachon
- gwinn, Michigan usa
April 30, 2011
April 30, 2011
Hi, Henry.
I'd say partial credit on that one :-)
You are correct that hematite (Fe2O3) is non-ferromagnetic and magnetite (Fe3O4) is ferromagnetic. But I think you'll find that once the materials are smelted into iron, it doesn't matter which oxidation state the iron was originally in, and both can be made into steel, magnetic grades of stainless steel, and non-magnetic grades of stainless steel.
Q. I have come across the problem of non magnetic stainless steel a lot over the last 12 months, as the firm I am contracting with want all there stainless steel m/c parts to be non magnetic, but I have found this not to be possible . As the part have a lot of different machining processes done to them. We have used different grades, i.e., 303 & 304 etc, but at then end of the day there is alway some magnetic attraction. 302 grade is meant to be non magnetic but you can't get hold of it in any real material sizes.
Paul Nobbs
- Stevenage, Herts, UK
September 8, 2011
A. Austenitic Stainless steels are generally non-magnetic (face centered cubic structure) but Ferritic and Martensitic Stainless? steels usually are. A fairly graphic demonstration can be given by heating a piece of Carbon Steel with a magnet attached, when the steel reaches the Austenitic transformation temperature the magnet will fall off.
George Waite
welding engineer - Totnes Devon UK
October 5, 2011
Q. So, if hematite (Fe2O3) is a non-ferromagnetic and can made into Steel or Stainless steel, does the raw Steel type, before any processes (cold or hot), exhibit any magnetic properties. Or, is it still non-magnetic with less corrosion resistance and less tensile strength?
Samuel Monroe
- Sarasota, Florida
October 7, 2011
Stainless Steel Armature Plates for Maglocks
Q. I have an armature plate from a maglock. It appears to be stainless steel of some sorts. I cut a piece of the plate off with a hacksaw and could see that the metal was uniform throughout. In other words, it is not mild steel that has been plated. I thought stainless steel was non-magnetic.
My need to know is based on the following. I have been approached to make Maglocks for a customer. It would be helpful if I could bypass the learning curve of finding out what materials need to be used.
Adrian Carboni
Product Designer - Johannesburg South Africa
October 12, 2011
A. Hi, Adrian.
I don't know what the item is made of, and I suspect that just cutting it in half and observing with the naked eye won't give enough info. But, as mentioned, some stainless steels including the 4xx series are magnetic, not much different from plain steel. The 3xx series are theoretically non-magnetic (although cold working may make them slightly magnetic). Good luck.
October 12, 2011
thumbs up signThanks for the interesting thread. I was also under the impression that stainless was non-magnetic, but that myth has been busted.
Q. I do have a question regarding stainless steel appliances. I am curious whether one stainless is better than another. It appears that on this thread the non magnetic stainless goes thru an extra process and with the added nickel would seem more expensive to make and has better "healing" properties. I could then conclude that manufacturer spent more money for better quality? Or is that stretching it?
Erik Visser
- British Columbia, Canada
December 17, 2011
December 2011
A. Hi, Erik. No, I don't think that is stretching it at all.
18/8 (8% nickel) or 18/10 (10% nickel) is not only more expensive than 18/0 (0% nickel) because of the cost of the nickel, but it is more corrosion resistant. Yes, the manufacturer spent more on 18/8 or 18/10 and it is a better material for appliances.
If the appliance is magnetic it is not necessarily true that it is not stainless, so the manufacturer isn't necessarily misleading you -- but I personally would bring a magnet to the appliance store and not buy any appliance that a magnet sticks to.
A. Dear Sir
We have been manufacturing magnetic 302 stainless steel wires with tensiles in excess of 3000MPA for decades. This is simply a property characteristic that results from producing zero stress relaxation arch wires for Orthodontics. It is commonly known as Australian Light Wire or A J Wilcock Orthodontic Wire. Initially, the raw material is Austenitic and non magnetic, however, after the processes of thermo-mechanical work hardening and repetitive dynamic strain aging it becomes Martensitic and highly magnetic. Some wires have been known to have yields in excess of 3000MPA in the straightened condition! We have made tons of the stuff over the last 65 years. Sincerely
Arthur Wilcock
- Strasbourg France
April 29, 2012
wikipedia
Hematite
Magnetite
Q. Hi my problem is I'm trying to weld 316 stainless down-hole electric motor that is full of magnets that give me really bad arc blow.
I was wondering what my best welding process would be? SMAW DC will not work at all; GMAW works somewhat, but we are getting porosity and we need a seal weld.
Thank you for your time.
Sheldon
Sheldon Martin
- Edmonton,Alberta,Canada
September 17, 2012
Q. Hi, I am working in an elevator company and my company has provided 304 grade panels to the customer while inspection he found out that my lift panels are having magnetic property and he is now not ready to take the lift. How can I support my company in this aspect?
IZAZUR RAHAMAN
- Pune, India
July 3, 2015
"Hand-Held X-Ray Analyzer
x_ray_alloy
A. Hi Izahur. As you have read, type 304 stainless steel can become somewhat magnetic from cold working, but there are many accurate test methods, and magnetism is not among them. A alloy sorter / scrap sorter this on eBay or Amazon [affil links] x-ray fluorescence machine can determine the answer instantaneously if you can find a test lab or a scrap yard that has one. Further, your certifications may constitute proof of construction material.
If the material is only slightly magnetic, it probably is type 304 and you should be able to prove it. But if the material is strongly magnetic, as magnetic as a piece of plain carbon steel of the same thickness, you might be looking at challenging your vendor rather than your customer because you certainly didn't cold work it to the extent that Arthur cold works his wire :-)
July 2015
Why is stainless jewelry so expensive
Q. Someone said that stainless steels are not precious metal like gold or even silver so he didn't understand why we were asking whether the stainless steel jewelry was fake or not. Well, go to Walmart and you'll find a small thin chain; this is stainless steel and it costs anywhere from 100 to $300 -- so that's why we're asking if it's fake or not? Why does stainless steel whose value is only cents on the pound all of a sudden cost $200 for an ounce.
thomas_marion
Thomas Marion [returning]
- Arlington, Texas
September 12, 2015
A. Hi Thomas. Yes, I did say "I don't know exactly what meaning you have in mind when you ask whether it [stainless steel jewelry] is 'fake' ". The problem is I still don't.
Not really made of stainless steel even though real stainless costs "only cents on the pound"? Not really made by the company whose name is on the box?
Please complete the sentence: By 'fake', I mean that it isn't really ______ ________ ________"
Some stainless is magnetic, some isn't, and I'm still lost. Thanks.
September 2015
Q. Hi. Okay I'll put it this way. No Stainless steel is fake. This is because it is not a precious metal, so there is no reason to fake it. But nowadays stainless steel is becoming more popular in jewelry. Retailers are selling it and there is no accepted standard as to what quality should come with what price tag.
You can get a ss ring at one place for $10-$20, and seemingly the same ring at another (i.e., Walmart) for $100. So when I walk into Walmart I see a ss necklace for $90 next to a gold necklace for the same or even $150, no matter what the Kt of the gold. This is wrong and companies everywhere are getting away with it. They aren't breaking the law. It's not fake -- you can ask for $1000 for a pair of socks -- it's up to the consumer to decide. But we put a certain trust in companies like Walmart. So what should stainless steel be worth as jewelry? And when I say fake I mean a 10Kt gold ring being sold as a 24kt. We need a standard. Thanks.
thomas_marion
- Arlington, Texas
September 15, 2015
A. Hi again. Okay, thanks, I understand you now.
You're right that stainless steel costs only a couple of dollars a pound whereas gold might be about $1000 an ounce. As long as you and other customers understand that stainless steel has no intrinsic value, and that you're buying artistry not metal, it's okay though. The same is true of tungsten and titanium jewelry. But the canvas and oils used by Renoir and Van Gogh only cost a few dollars a pound as well.
If the artistry of the jewelry doesn't attract you to want to spend that kind of money to have it, stick with gold. And since it's mass produced, the artistry is probably not worth the money. Best of luck.
September 2015
! You did understand the first part of what I was talking about with the stainless steel. About me saying it is fake is it truly meaning fake it's meaning quality. But with that portion settled the next comment was asking about a stamp on the inside of the stainless steel necklace; she was under the impression that that stamp represented the quality of the stainless steel. Normally it would represent that but, as we both have stated, stainless steel is not of any value and this is where the problem lies.
You said there is no reason or point in counterfeiting it as there is no market for it and you used the word counterfeiting because she used that word we both know that you can't count because it is not real in the first place but a lot of the general public do not know that and this is what I was talking aboutIn the second part if you were to go to a jewelry store and there were two $2000 gold necklaces that seemed identical but after buying one you found out you bought 10 karat gold necklace and the other one at the same price was 24 karat, that would make you pretty mad; extremely mad if you ask me.
This is exactly what these companies are doing that are selling the stainless steel chair -- not breaking the law by doing this it is not illegal, simply immoral, it's taking advantage of the general public to come to a jewelry store and expect to have fine jewelry. I know it's stainless steel but they are tricked into believing stainless steel is worth something when it isn't. If companies are going to start selling these stainless steel jewelry pieces for hundreds of dollars simply put there needs to be a law put in place, where it is mandatory for the piece to be stamped with what kind of stainless steel. It is the reason this is not down on law yet is because of what I said earlier there is no standard for which kinds of stainless steel might be better quality. Obviously the higher quality stainless steel would be the kind that is harder to make; it is true stainless steel, nonmagnetic. The magnetic times like 440 are made much cheaper; they're done this way to save money and in my opinion it shouldn't be stainless steel at all at that point, or at least it should be stamped with a much lower grade. They have been stamped; it's just the stamps have never represented quality just the type ... so, concluding, selling a 24 " gold necklace and a 10 carat gold necklace without you knowing which one it is for the same price would be the same as selling a stainless steel necklace that is nonmagnetic compared to one that is magnetic; the standard isn't there and it needs to be because the general public is being taken advantage of by companies knowing that they don't know the difference and there is a difference but they're making money off of it so there is a market for it.
thomas_marion
Thomas Marion
- Arlington, Texas
November 26, 2015
A. Magnetism is a hunting electron to other side, so some stainless steels have a different type of molecule combination (according to its carbon or other material contents) and it can be attracted with a magnet. Is it a fake steel? Truely: it's not a fake but this kind of steel may not be approved by someone or company. If your work does not intvolve magnetics (if there is no problem with magnetic poles) you can choose that type of steel.
Arslan Haydarow
- Turkmenabat,TKM, Turkmenistan
September 25, 2015
A. Stainless steel has such a broad definition it's hard to communicate facts about it. "Surgical grade" is one of my favorite nothings. Sounds like the Indian guy us pulling a fast one on his customer though.
Roger Simmons
- Minoh, Osaka, Japan
September 26, 2015
Jewelry is marked '316'. Is it stainless or fake?
Q. If jewelry is "stainless Steel" wouldn't that be stamped on the inside? I don't think what I bought is legit SS. The stamp is '--316' ... unless the 316 is the grade of SS?
tina_rakowski
Tina Rakowski
- Grand Forks, North Dakota, USA
November 18, 2015
A. Hi Tina. Yes, '316' probably means Type 316 Stainless Steel. As mentioned earlier, stainless steel costs only a few dollars a pound (thousands of times less than gold, 10-100 times less than silver) so there really isn't much market for 'counterfeiting' small items that would have a scrap value of only 50¢ if genuine. So I think your jewelry is 316 stainless. Enjoy it.
November 2015
A. I can clarify something regarding Surgical Stainless Steel, aka 316L, as well as Titanium and why it can matter whether something is or is not what it purports to be.
316L and Titanium are two materials used in jewelry by professional piercers. Metal allergies (e.g. Nickel) are quite common and can lead to infection or prevent healing if used in fresh piercings by susceptible individuals. And some materials are more porous than others and accumulate bacteria, being harder to effectively sterilize can also contribute to developing an infection. Most professional piercers have a short list of materials that are suitable for use based on these types of considerations; it can be important for health reasons. I came across this page because I got a magnetic paper clip cup to store my spare 316L earrings in. I expected it to be magnetic and therefore secure in the cup because I have in the past used magnets on stainless steel appliances in kitchens. I learned to my partial dismay that neither my 316L jewelry (nor my Sterling Silver, though I expected that) attracts to the magnet and I got to wondering if that might be a way to rule out something that purports to be 316L or Sterling absent a certification.
I don't know if it's merited by the raw material cost, but as a consumer I can tell you that jewelry that is 316L or Titanium is typically significantly more expensive and that I need a level of confidence that they are not likely to irritate my skin if I am going to pay the extra cost. It's not about being precious, it's about being hypoallergenic.
Rhy M [last name deleted for privacy by Editor]
- San Francisco, California, USA
January 14, 2017
How to Make Iron Non-magnetic
Q. Hi. Is it possible to make Iron into non-magnet (Magnet-less character)?
Please reply if any options.
Arun Kumar
- Bangalore, Karnataka, India
April 6, 2018
April 2018
wikipedia
Degaussing
Ferromagnetism
Hi Arun. If you could please tell us who you are, what you do, and why you want to know I am confident that you will get a more helpful and insightful response. Readers tell us that they find vague questions dull & repetitive but are often intrigued by people's actual situations :-)
Magnetism (where the piece in question attracts other iron objects) can be removed by degaussing, generally pretty easily. But when people talk about iron being "magnetic" they usually actually mean "ferromagnetic" (a magnet will attract the item in question). I do not know of any way of 'turning off' the ferromagnetism of an iron object; but obviously you can alloy iron with sufficient other ingredients as to make it non ferromagnetic like Series 3XX stainless steels.
