Gold did not precipitate as anticipated :)
Sulfurous acid is known to destroy the excess nitric acid and eventually precipitate gold from the gold-aqua regia solution. I tried adding an excess of 5-6% of its AR grade. After a while brown clouds appear and get denser. However, it also easily disaappeared as the solution warms up. The solution's color turned from reddish orange to a much lighter yellow orange. What could possibly be wrong that the gold did not precipitate? Should I use another reducing agent?
Tim Carino- Philippines
