Electroforming Process Set Up
Dear Sir,
I'm working on process "Electroforming", I wish to know about its applications & min. requirements to put a set up for manufacturing. I'm eagerly waiting for your valued reply.
Paresh Deshpande- Kolhapur, Maharashtra, INDIA
Electroforming is the same process as electroplating except that the substrate which has been plated is removed, and the plating layer itself becomes the functional part.
Hi Paresh:
For detailed information on applications and requirements you might contact the Nickel Development Institute in Toronto, Canada. They will flood you with valuable information.
Some of the items being made in India are Ice-cream factory moulds, Sugar Mill Meshes, imitation jewellery dies and moulds, etc. The cost for a plant should be within Rs 2.00 laks for a single tank prodn.line.
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
