Musty smell in house
How do you get rid of a musty/mildew smell from and basement and house? The basement was recently emptied of everything after many years but a smell exists in the basement and house.
Joanne Fox- Toms River, New Jersey
Joanne,
Re your musty smell, firstly you could perhaps phone up the local fumigators for advice.
Secondly, if you have a hot air ventilation system, maybe there is something you can spray into it to reduce the odour. Certainly with cars having air conditioners they can, after some time, stink somewhat. The local car stores sell a spray can to alleviate this. Sure worked l00% with a Probe after just one application ... my daughter was happy
Thirdly, ... and this is a pain in the neck ... you can swab all the floors with bleach
⇦ bleach/sodium hypochlorite in bulk on
Amazon [affil links]
to kill off those odour producing mites.
Fourthly, go to the Web ... and you'll find better advice, I'm sure.
Freeman Newton [dec.]
1)Remove all sources of moisture and any damp, mildewed materials if possible(carpet is the usual suspect). Treat all exposed and mildewed surfaces with a strong bleach/water solution. Then dehumidify the air as much as possible.
2) Buy a marine-grade ozone generator. (Do not use it while the basement is occupied)
3)Re-Paint the walls, floors and ceiling.
Bob Zonis- Bohemia, NY
