Plate Aluminum
I want to repair a crack in a diaphragm made of aluminum foil. The only way I can think of is plate that part locally and use solder to repair it. I can think of tin and silver. Can anyone give me a hint of how to plate it and will the repair hold at 15 kHz vibration.
Wasim Chowdhury- Hartford, Connecticut
Hi, Wasim.
15kHz? Is this a loudspeaker? If the original diaphragm didn't hold, the repair won't hold either. Are you sure it's aluminum foil, not mylar with a shiny aluminized finish?
Anyway, yes, it is possible to electroplate aluminum but it's not easy, and this would have to be a very high value component before it could be feasible.
