Alternatives to FFKM
Hi,
I am looking for a cheaper alternative to FFKM elastomers for a high temperature application (250 °C). Is there any way to get this around? Maybe by doing some kind of plating on the regular types of elastomers e.g.,silicon rubber? Any comments? Thanks in advance.
Teck Beng Ting- Singapore
I don't know your application, have you thought about encapsulated silicone O-ring with a Teflon PFA or FEP lining. It is not as flexible as Kalrez but to my opinion can withstand high temperatures and has good chemical resistance properties.
All the best,
Jelle Heins- Hoek of Holland, The Netherlands
Try AFLAS material. It can withstand temperatures of 260 °C.
Peter CloneyPrecision Polymer Engineering Ltd - Blackburn, England
