Refinishing a Chrome Baby High Chair
I have a thirty-year-old high chair that is chrome except for the vinyl-padded seat. The chrome has rust spots scattered on all surfaces--- the arms, legs and tray. The structure itself is very solid. What is the best way to remove the rust and then paint it? I want a paint that will be non-toxic, durable and will not chip.
Mina Webster
- K.C., Missouri, USA
You could grind the rust off with sandpaper, or you could dissolve it using muriatic acid this on eBay or Amazon [affil links] . (If you use muriatic acid, please be careful) There are also a few specialized solvents out there designed to get rid of rust. Ask someone at your local hardware store.
I'm not much help in suggesting a paint. My knowledge is limited to large-scale industrial painting processes. You may want to ask your hardware store about that too.
tim neveau
Tim Neveau
Rochester Hills, Michigan
To take off light rust use break fulid wipe it on heavy and let it sit for about 20 min...then wipe off with a brillo this on eBay or Amazon [affil links] or SOS pad this on eBay or Amazon [affil links] soaked in hot water...if rust is heavy take the brillo pad and put some brake fluid on it then rub rust away. Make sure you wash away all dirt before you get started.
Rick Rubin
- Berlin, Connecticut
