Anodize Seal quality test
Hi,
Could you please specify how to do seal quality test with ink for chromic anodize coating?
Owen Y. Liao
- Barrie, On., Canada
British Standard 3987:1974, anodic oxide coatings on wrought aluminum for external Architectural applications is a test, sorry, I don't see the use of ink anywhere, and it might be for sulfuric anodized parts, but I gave it a try.
The "stain resistance test" as we call it can be found in detail in the ASTM document titled ASTM B136 "Measurement of stain resistance of anodic coatings-test method" Your local Document center should have this. Basically a 50% nitric acid is applied to a small area (drop or two) of the part and left on for 6 minutes after which it is wiped with a clean damp cloth. A Blue dye is then applied for a particular period and after wiping again no absorption of the dye should have occurred. This test should not be used for 2000 series alloys containing high 4% copper.
Bill Grayson
- Santa Cruz, California, USA
