Body filler over powder coating
Anybody know of a body filler that stick on powder coated metal? I have tried Bondo ⇦ this on eBay or Amazon [affil links] , but it does not stick. Any suggestions? Thanks!
Ferdi Tjandra- Stone Mountain, Georgia
I found that a bakeable caulking works good as a body filler. It takes a little more work.
Step 1 I found that if you put it on in thin layers and keep adding caulking with your desired tool, making sure you keep the bubbles out. Don't get to concern about the ridges.
Step 2 Bake for 60 minutes at 240 F.
Step 3 Let it cool for awhile. DO NOT COOL TO QUICKLY. Make sure it is all at the same temperature before moving on.
Step 4 Sand down.
Step 5 Repeat if necessary.
Step 6 Powder coat and bake.
Kelly L. WunschWheatland bins - Ohaton, Ab, Canada
Ed. note: Dura-Chem has developed a solvent-free filler specifically for powder coating.
