Looking for non-stick surface treatment for PP, PE, etc sealing
I'm looking for a coating that can be applied in-shop which has non-stick properties with regard to PV, PE, and PP films, which can tolerate up to 400 degrees. Application is heat-sealing films together...
Roger Hayes
Aksys Group, L.L.C. - Amarillo, Texas
How about anodized aluminum with Teflon filled into the pore space?
