How to do passivation
I have a porous media in Stainless Steel 316L. I need to form a passive layer around the particles to achieve radiative properties of a non-metallic (for Heat Tranfer studies). How can I do the passivation and control the thickness of the passive layer?
Sheila HitUniversidade de Aveiro-Dept Mecanica - Aveiro
Hi Sheila:
I know that stainless 316L, as well as other free machining stainless steels is passivated by immersion in 20% nitric acid (at 70% conc.)+ 4-6% sodium dichromate + water by 30 min. If substrate is porous, special steps might be required to permit capillary action (perhaps temperature changes to soak it in). This treatment will attack lead. What I don't know is if it will change radiation properties and give you what you want.
Good luck,
Sheila:
Refer to ASTM A967-99. This specification will allow you to use a much better solution than the dangerous nitric acid. citric acid formulations are available on the marketplace that do a better job, and safer.
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
