Electroless tin plating over bright chrome plating
I want to have some information about electroless tin plating on brass parts. If we try to electroless tin plate a bright-chrome plated brass part, does the tin plating effect the chrome plate or does it only effect non plated internal surface of the part?
Ozkan Bekiroglu
- Bozuyuk, Bilecik, TURKEY
Dear Mr.Bekiroglu,
If you want to obtain bright tin finish you can directly go to immersion tin process without chrome over brass.
FREDI YARCAN
- Istanbul, Turkey
