Filter Press
Dear Sir,
I'm using Filter press 16"X16"X16 Nos for Manganese Sulphate production, whereby there is a Plunger Pump with feed line of 1".When the pressure in the press increases to 50 to 55 lbs/Sq inch,the pump starts spurting the liquid from the plunger side . My question is what are the alternate pumps that I can use, for this small filter press?
Raghu Khemka- Nagpur
Air powered diaphragm pump is what we use for sludge de-watering with a filter press because:- it is self priming, when the press is blocked the pump just stalls, the pump can run dry, it can operate up to approx. 100 psi. Downside you must have compressed air.
Martin Trigg-Hogarth
surface treatment shop - Stroud, Glos, England
