Plating and finishing kovar
I am packaging an electronics module using kovar. The package will be hermetically sealed. Some of the connectors are to be laser welded to the package while others are to be soldered/brazed. What type of plating will be required such that the soldered/brazed connectors can be assembled properly. Will kovar require any special finish to prevent corrosion?
Doug BarkerITT Industries - Annapolis Junction, Maryland, USA
Depending upon the conditions to which the part will be exposed, you might need as much as 4 - 6 tenths of Watts nickel, 3 or 4 tenths of a mil of cadmium, then Olive drab chromate.
0.0003 inches of Watts or sulfamate Nickel should be the underlayment for the solder.
