Epns cleaning
I would like to know the best way to clean epns silverware as mine is black and most silver cleaners tend to make it worse. Any suggestions?
Mavis Northmore
- UK
Mavis,
You can buy (I forget the name) a silver cleaning kit consisting of a piece of aluminum with 'instructions'.
You could get some flat pieces of aluminum (I'm pretty sure it is aluminum), put them in a bowl with the metal epns (knifes & forks, perchance?) touching them. Then get some hot water and add some dollops of sodium bicarbonate (i.e., good old baking soda [in bulk on eBay or Amazon [affil links] ). Leave to 'stew' for a day or so. An electrolytic action will occur and the black, or some of it, will/should disappear.
It does work ... for fine tuning you might have to use some silver polish. Works on pure silver, too!
Cheers!
freeman newton portrait
Freeman Newton [deceased]
