Thread 107/27
RESTORING ALUMINUM PONTOONS
CLEANING PONTOONS IS A [big] JOB, WOULD LIKE SOME ANSWERS ON THE BEST WAY TO SOLVE THIS CLEANING JOB.
CHUCK S [last name deleted for privacy by Editor]- BROWNSVILLE, TEXAS
publicly reply to CHUCK S
Clean the pontoons of oxidation, algae, grease, or barnacles? An answer of 'yes' not allowed:-)
publicly reply to Tom Pullizzi
I need to know how to clean the pontoons on our pontoon boat. It has been out of the water all winter.
Nancy G [last name deleted for privacy by Editor]homeowner - Manchester, Kentucky
publicly reply to Nancy G
Hi, Nancy. Probably start with barnacle remover ⇨
if it's a salt water boat and has barnacle accumulation.
Then clean with a hose (or preferably a pressure washer!).
Then use aluminum pontoon cleaner .
Good luck with it.
publicly reply to Ted Mooney
Hi, I am in need of a cleaner that will remove or dissolve the buildup on the pontoon below the water line. This boat has not been out of the water since 1994 and the buildup next to the skin is as hard as a rock.
I have been using a scraping tool as well as a power wire brush but at the rate I am going it will be over a year before I finish. I need something that will dissolve this what I call calcium buildup or at least soften it so that it can be removed.
Andrew Gloverpontoon boat owner - Arleta, California
October 8, 2009
publicly reply to Andrew Glover
Hi, Andrew
I believe you are right that these growths are primarily calcium. Aside from pontoon cleaners made for the task, you could try C-L-R
⇦ this on
Amazon [affil links]
or Lime-Away
⇦ this on
. Stronger acids like muriatic acid
⇦ this on
Amazon [affil links] will very likely work, but are hazardous materials requiring rubber gloves
⇦ this on
Amazon [affil links] , goggles
⇦ this on
Amazon [affil links] , good ventilation, and a lot of care. Good luck.
I want to know if you can tell from the photos if
1) Barnacles caused the pitting, not the paint (that is what I think since the pitting is above the water line, and I saw the barnacles in the pitting area before they were removed)
2) If it can be seen if there is a primer, or a way for me to tell.
3) How do I know if this is a problem, and I must immediately remove it?
4) If it has to be removed, with what method.
Thank you in advance.
Hobbyist - Pentwater, Michigan USA
May 11, 2010
I bought a used pontoon boat.
It appears to have had barnacles on the boat, causing pitting in the aluminum tubes. The previous owner painted the bottom, but I cannot tell if anti fouling paint was used without primer.
publicly reply to Matt Stocke
Ed. note: Some good threads about aluminum pontoons include letters 21588 and 31788.
