Thread 107/21
Metal prep prior to painting for refinishing firearms
Hello, I am refinishing firearms. Currently I only refinish parked firearms and use gun kote from KG industries. I am looking for a process to treat metal prior to painting that will provide a good adhesion for the paint. I have been told that Phosphoric acid may be what I want? Also can anyone recommend another product for refinishing that provides good resistance to wear and the elements.
Any help would be greatly appreciated.
William Edward Sayre- Alcalde, New Mexico, USA
publicly reply to William Edward Sayre
Phosphoric acid by itself won't give the pre-paint finish you're looking for. Find a good iron phosphate cleaner/phosphatizer combo for best results. By the way - a hot black oxide coating is also a good base for paint!
Dan Brewerchemical process supplier - Gurnee, Illinois
publicly reply to Dan Brewer
