Contact Points on Anodizing Plant Make Poor Contact
What form of flight rail (spline) is used out there at the contact point. I am currently using a V block connection, where one aluminium V from the flight rail fits into the conductive aluminium V. I would like to know if there is a better way to have a connection or better method, material, and so forth, as my results are coming out varied at the moment.
Also if there is somewhere I could find more info regarding this would be appreciated.
- Christchurch, New Zealand
Your nomenclature is a bit different from mine, so forgive any confusion, but if you are talking about the V-saddles on an anodizing tank, and the workbar from which the anodizing racks hang, the contact points should not be aluminum. You should use copper V-saddles and bolt copper contact shoes onto your aluminum workbar.
Wire brush the aluminum and the copper where you will bolt them together, then apply a oxide resistant compound like No-Ox-Id from Sanchem ⇨
