Iridite finish spec for aluminum
     Aluminum is often 'chromate conversion coated' as a corrosion resistant final finish or as a pretreatment for painting or powder coating. The process actually involves many steps, usually including alkaline cleaning, etching, deox/desmut, the chromate conversion step per se, and water rinses between each step.
     MIL-C-5541 / MIL-DTL-5541 / MIL PRF-5541 is the most commonly cited spec. "Alodine" and "Iridite" are trade names. "Chem film" is a slang term for the process.
Q. My company has inherited a design including aluminum parts which are specified to be finished according to "IRRIDITE ^ Iridite 14-2". The shop that is now making the parts doesn't recognize this spec, and I have been unable to find it on the web or in any of the reference books I looked at.
Can someone enlighten me as to what this spec is?
Thomas McCarty
- Lake Forest, California, USA
probertEthumb
Aluminum How-To
by Robert Probert
Also available in Spanish
You'll love this book. Finishing.com has sold almost a thousand copies without a single return request :-)
A. Iridite is a Macdermid trade name for chromate conversion coatings, Thomas. Note that it has a single 'r', which may be why you had difficulty with your search.
A. Tom,
14-2 is not a spec it is a product, originally from Allied Kelite. It is a gold chromate on Aluminum. The spec is MIL-C-5541. And 14-2 meets it. There are non-chrome substitutes for 14-2 such as Sanchem 3500.
drew nosti
Drew Nosti, CEF
Anodize USA
Ladson, South Carolina
anodizeusa1
"The Surface
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
pinner
(note: this book is two volumes)
AbeBooks
A. Iridite 14-2 is a trade name for a chem film process like Alodine 1200.
What you could do is to change the spec to AMSC5541 class 1A (replaced Mil-C-5541 class 1A). This will get you from a trade name to an internationally recognised standard.
Martin Trigg-Hogarth
surface treatment shop - Stroud, Glos, England
Ed. update Mar. 2025: Martin may have been correct at the time, but MIL-DTL-5541 [⇦ this spec on DLA] is a current spec, it has not been replaced by an AMS spec.
A. Iridite 14-2 is a product.
There are many products used for chromate conversion aka chem film aka chemical conversion coatings.
Iridite 14-2 is just one of many products used to produce these coatings.
This happens to be the product we use here.
David A. Kraft
- Long Island City, New York
