Testing/analyzing Baths for Passivation of Stainless Steel
Q. I searched the Internet extensively looking for current testing procedures for passivation tank chemicals and came up empty. We have a cold Nitric bath and a hot Dichromate/Nitric bath for various stainless steels. There are a few titrations that are performed on a period basis and I would like to know where these test instructions can be found. We perform tests now, but I would like to reference the latest specifications in our manual. Any suggestions are appreciated.
Steve Szakacs
- Linwood, Pennsylvania, USA
A. Here is a procedure for the Dichromate Determination:
SCOPE: To determine the concentration of Sodium Dichromate in a solution.
EQUIPMENT:
2 mL Pipet
25 mL Buret
250 mL Erlenmeyer Flask
Deionized Water
0.1N Sodium Thiosulphate
100 mL Graduated Cylinder
0.5% Starch Indicator
10 mL Graduated Cylinder
Conc. Sulfuric Acid
10% w/v Potassium Iodide
1.000-1.250 Hydrometer
500 mL Graduated Cylinder
PROCEDURE: Using the pipet, transfer 5 mL of the sample into the Erlenmeyer flask. Using the graduated cylinder, add 100 mL deionized water to the flask. Using the graduated cylinder, add 5 mL sulfuric acid and 10 mL potassium iodide solution to the flask. Titrate with 0.1N sodium thiosulphate until the solutions turns to a straw color. Add 2 mL starch indicator to the flask and continue to titrate until the blue-black color disappears. Record the mL used as V1. Place 500 mL of sample in the graduated cylinder. Measure the density of the solution with the hydrometer. Record this value as "P".
CALCULATION:
C1= (V1*F1*N1)/P
C1 = Concentration of Sodium Dichromate in %w/w.
V1 = mL of sodium thiosulphate used in the titration
F1 = 2.483
N1 = Normality of sodium thiosulphate used in the titration.
P = Density of the solution
REPLENISHMENT:
W1 = P*V2
W2 = (C1/100)*W1
W3 = (C2/100)*W1
W4 = W3-W2
V3 = W4/453.6
V2 = Volume of the solution in milliliters
W1 = Weight of the solution in grams
C2 = Optimum concentration of Sodium Dichromate %w/w.
C1 = Actual Concentration of Sodium Dichromate in %w/w.
W2 = Weight of Sodium Dichromate in solution in grams.
W3 = Optimum weight of Sodium Dichromate in grams.
W4 = Weight of Sodium Dichromate to add in grams
V3 = Weight of Sodium Dichromate to add in pounds.
Ira Donovan, M.S.F.
Kansas City, Missouri
A. There are several books that can be ordered through ASM International and AESF that provide procedures for analysis of metal finishing solutions. Here is a procedure for the determination of Nitric Acid:
SCOPE: To determine the concentration of Nitric acid in a solution. EQUIPMENT:
5 mL Pipet 25 mL Buret 250 mL Erlenmeyer Flask Deionized Water 1.0 N Sodium Hydroxide 100 mL Graduated Cylinder 0.1% methyl orange ⇦ on eBay or Amazon [affil link] Indicator Solution
PROCEDURE: Using the pipet, transfer 5 mL of the sample into the Erlenmeyer flask. Using the graduated cylinder, add 100 mL deionized water to the flask. Add 5-10 drops of the methyl orange ⇦ on eBay or Amazon [affil link] indicator to the diluted sample. Titrate with 1.0N sodium hydroxide. The solution will change colors from orange-red to yellow. Record the mL used as V1. CALCULATION:
C1= V1*F1*N1 C1 = Concentration of Nitric acid in %v/v. V1 = mL of sodium hydroxide used in the titration F1 = 1.27 N1 = Normality of sodium hydroxide used in the titration. REPLENISHMENT: W1= [(C2-C1)*V2] / 100 W1 = Gallons of Nitric acid to add to the tank C2 = Optimum concentration of Nitric acid in %v/v. C1 = Concentration of Nitric acid in %v/v. V2 = Operating volume of tank in gal.
Ira Donovan, M.S.F.
Q. I have a passivation line that is 20-25% Nitric acid at 120 °F. Is there a simple tester that I can use to monitor concentration? I would prefer something you could just dip in the tank and measure the concentration. A glass hydrometer would work, but the operator would have to handle the acid.
Joe
Joe Dille
- Hatfield, Pennsylvania USA
October 15, 2010
"The Canning Handbook of Surface Finishing Technology"
canning
A. Working through the math of the nitric acid procedure, V1 mL of N1 NaOH can neutralize V1*N1 mmol of HNO3, which is equal to V1*N1*(63.01) mg of HNO3.
Dividing by the number of mL in the sample produces a concentration (for a mL sample) of V1*N1*12.6 mg/mL, which produces a value of V1*N1*1.26 %w/v, not %v/v.
The Canning Handbook (pg. 772 of the 21st edition) supports this correction, and provides correct factors to find %v/v terms of concentrated solutions of nitric acid (1.46 for SG 1.38 and 1.30 for SG 1.41).
Joshua Meisner
Aerospace - Long Island, New York
March 9, 2012
Q. I see in the Equation above for sodium dichromate concentration that we use a factor F1. Where does that factor come from? I'm curious to know how we determine that factor.
Peter
Peter Totaro, Chemist
metal finishing - paterson New Jersey USA
November 20, 2014
A. Peter,
The F1 constant in the titration equations is just hiding all of the other math involved. If you run the numbers from scratch and trace through all the stoichiometry, dilutions, etc., the number given for F1 should appear. In procedures such as this, the math is typically "precooked" since the intended user is only interested in the final answer and might not have been a chem major.
ray kremer
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
December 1, 2014
Q. Is there a book or something else that will step through the math to get this F1 number? I have seen this number (2.483) in multiple places, but I need to see how this number was calculated.
Julie
Julie Stasiak
- Tucson, Arizona, USA
December 3, 2014
Q. Is there someone that can explain to me how to get the F1 constant? I have been trying to find it with all the dilution, titration calculations but cannot get the F1 constant. Please help! Thanks
Nathania Yuliani
- Santa Ana, California
December 12, 2016
December 15, 2016
I have to confess, I don't know where 2.483 comes from either. I'm getting a totally different number.
I managed to find something that explains the reactions involved at
http://www.meduniv.lviv.ua/files/kafedry/tokshim/English/Analytical/Manuals_Analytchem/Iodometry.pdf
Essentially, adding the Potassium Iodide and Sulfuric Acid generates 3 moles of iodine (I2) for every mole of dichromate in solution. The iodine is then titrated by the Thiosulphate with an equivalence of 2 moles Thiosulphate per mole of iodine.
The normality of the thiosulphate solution would seem to be equal to molarity (mol/L) here.
So you have your mL of titrant (V1), divide by 1000 to convert it to liters, multiply by the molarity (N1, though assigned as 0.1 in the procedure) to convert to moles of thiosulphate titrant, divide by 6 to convert moles thiosulphate to moles dichromate, and multiply by the molar mass of sodium dichromate (261.97 g/mol) to get the grams of sodium dichromate present in the original 5 mL sample. Now for %w/w, you need to divide that by the total mass of that original sample, which is its density times 5 (for the 5 mL).
Stringing all that together, the F1 in %w/w = V1*F1*N1/density
would presumably be 261.97/(1000*6*5) = 0.0087323
I rather suspect I'm missing something here.
ray kremer
Ray Kremer
McHenry, Illinois
December 15, 2016
I have tried carbon treating my cyanide bath. It has helped a bit. But the problem is not solved completely. At low current density areas. There is pitting like patterns. The problem is coming on flat surfaces at low current density areas.
At high current density areas, there is no pitting.
The pitting looks like small dots all over the surfaces of low current density areas.
I am not using Rochelle salt ⇦ on eBay or Amazon [affil link] at all.
My bath is completely based on copper cyanide and sodium cyanide.
There was no such problem in the beginning.
Whenever problem arises I add 5kgs of copper cyanide and 7.5 kgs of sodium cyanide. It generally resolved my issues in the past.
But now carbon treating and additions of copper cyanide and sodium cyanide is not helping.
While carbon treating I had used 500grams to 650 litres of solution.
It is adamant to the solution?
I had also tried dummying.
In the dummy also small bubbles like roughness is appearing on low current density areas.
Is this pitting is because of impurity or I need to add some copper cyanide and sodium cyanide to the solution.
Please help me out.
Nikhil Sharma
- jalandhar, Punjab, India
